You can use this command to correct a corrupted pointer in the Externalization Server subgroup queues or blank all the subgroup queues. The Externalization Server subgroup queues hold one entry for each Virtual Volume waiting for Externalization.
A bad pointer could cause a circular queue reference, leading to an endless loop. This would be detected and result in an error message. This error can be corrected with the RESET option. CA Vtape scans the existing subgroup queues' entries sequentially and rebuilds the pointers causing the problem.
If RESET is unable to resolve the problem, INIT may be used to reinitialize the Externalization Server subgroup queues. In this case no entries are added back and the queues remain empty until the batch utility GRRJCL is run to dynamically rebuild the queues.
SVTn QUEUE {Init|Reset}
