Previous Topic: MIHCLEAR =Next Topic: QUEUE
MOUNT=
This command redrives a mount for a Virtual Volume on a Virtual Device that is in mount pending status. If the Virtual Device is waiting for a Recall to complete and the RESTART BACKSTORE command is issued or CA Vtape is forced down, when the Backstore Engine is restarted, the Virtual Device will be active with a status of mount pending. The mount will be redriven automatically after a short delay. You can use the MOUNT command to eliminate the delay and immediately remount the previously requested Virtual Volume, and the Recall will be redriven.
Syntax
SVTn MOUNT=nnnn
Where nnnn is the address of the Virtual Device.
