Previous Topic: Selected Physical Input Volume Pull List ReportNext Topic: Automating the Exclusion of Retained Backstore Volumes
Physical Input Volume Status Report
Report SVTRC190.B is the post Recycle or Recycle results report. The report is broken into two sections as follows:
Note: Physical volumes with no remaining physical files are written to the SVTR190B DD statement file. This file can be used as input for return-to-scratch processing at those sites without a tape management system.
Example of the SVTRC190.B report
RECYCLE.SVTRC190.B  CA11.SVT2                            CA VTAPE                          HH:MM:SS mm/dd/yy  PAGE#    24 CA Vtape r11.5                        SELECTED PHYSICAL INPUT VOLUME STATUS REPORT                                               REPORTED BY PHYSICAL VOLSER       PHYSICAL  --#PHYSICAL FILES--------------- GROUP VOLSER     SELECTED  PROCESSED  REMAINING ----- ------    --------------------------------    61 540336            3          3          0    61 540476            3          3          0    61 540520            3          3          0    61 540562            3          3          0    61 540692            3          3          0    61 541202            5          5          0    61 541284           18         18          0                 --------------------------------        TOTAL           38         38          0                                 TAPE CONSOLIDATION RATIO PHYSICAL OUTPUT VOLUME SUMMARY                                                ACTUAL RUNTIME STATISTICS                                                    REPORTED BY GROUP         ACTUAL   REQUESTED   ------------#PHYSICAL VOLUMES----------- GROUP    TCR        TCR       SELECTED  PROCESSED  RELEASED  WRITTEN -----  -------    -------    ----------------------------------------    61   (7:1)      (5:1)             7          7         7        1                              ----------------------------------------                    TOTAL             7          7         7        1
Note: The REMAINING column of report SVTRC190.B always depicts the number of physical files that are cataloged to the source volume; therefore, if a RECYCLE control statement does not define a target tape type (Primary or Duplex) that includes the source tape type, the number of physical files shown in the REMAINING column will be equal to or greater than the number of processed files. This is because the files residing on the source volume were not recycled (read and recataloged to a different tape), but read to create a tape of a different type. This occurs when the following RECYCLE control statements are used:
RECYCLE SOURCE(PRIMARY) TARGET(DUPLEX)
RECYCLE SOURCE(DUPLEX) TARGET(PRIMARY)
RECYCLE PHYSICAL(VOLSER) SOURCE(REPAIR)
When a RECYCLE control statement defines SOURCE(PRIMARY) with TARGET(PRIMARY|BOTH) or SOURCE(DUPLEX) with TARGET (DUPLEX|BOTH), the REMAINING column of the report will reflect a true RECYCLE of the input tape. If a tape with ten files is selected and six files are processed, four files will be reported as REMAINING. If all ten files were selected and processed, then the REMAINING column will show a file count of zero, indicating that the input volume can be returned to scratch status.
