Previous Topic: RECYCLE Command Processor Report Message DescriptionsNext Topic: Excluded Virtual Volume Files
Included and Excluded Physical Volumes
Report SVTRC125.A0 lists the physical volume serial numbers defined by the Include Physical Volume List (Recycle JCL PINCLUDE DD statement file) and the Exclude Physical Volume List (Recycle JCL PEXCLUDE DD statement file). The physical volume serial numbers are listed in ascending order and the respective volume is tagged as originating from the Include or Exclude Physical Volume List. The report also indicates the total number of volumes defined by the PINCLUDE and PEXCLUDE files and the designation of the physical volume (Unknown, Primary, or Duplex).
Example of the SVTRC125.A0 report
RECYCLE.SVTRC125.A0 CA11.SVT2                           CA VTAPE                          HH:MM:SS mm/dd/yy  PAGE#     1 CA VTAPE R11.5                        INCLUDE/EXCLUDE PHYSICAL VOLUME LIST REPORT GROUP# N/A                                     SORTED BY PHYSICAL VOLSER  PHYSICAL                               PHYSICAL                               PHYSICAL                                PHYSICAL  VOLSER   TYPE   ACTION    VOLSER   TYPE   ACTION    VOLSER   TYPE   ACTION    VOLSER   TYPE   ACTION  ------ ------- --------   ------ ------- --------   ------ ------- --------   ------ ------- --------  540336 PRIMARY INCLUDED  540476 PRIMARY INCLUDED  540520 PRIMARY INCLUDED  540562 PRIMARY INCLUDED  540692 PRIMARY INCLUDED  540701 PRIMARY INCLUDED  540701 PRIMARY EXCLUDED  541053 PRIMARY INCLUDED  541085 PRIMARY INCLUDED  541202 PRIMARY INCLUDED  541284 PRIMARY INCLUDED SVTSRC042I 10 Include volume(s) specified:            00 Unknown, 10 Primary, and 00 Duplex SVTSRC042I 01 Exclude volume(s) specified:            00 Unknown, 01 Primary, and 00 DuplexIf a VOLSER is in both Physical Volume Lists, the exclude takes precedence and the VOLSER is excluded from processing. If all VOLSERs are in both lists, RECYCLE will terminate with a return code of four and the following message:
SVTSRC043I No candidate virtual volumes to recycle.
If a Physical Volume List has no VOLSERs, an SVTSRC041I error message will be printed for the empty list.
