Previous Topic: ReportsNext Topic: RECYCLE Command Processor Report Message Descriptions
Command and Input Parameter Syntax Check
Report SVTRC100 documents the command and input parameters coded for the current execution of the RECYCLE Utility and any problems found with those commands and input parameters. The following are examples of the SVTRC100 report.
Example 1 of the SVTRC100 report
RECYCLE.SVTRC100    CA11.SVT2                          CA VTAPE                            HH:MM:SS mm/dd/yy  PAGE#     1 CA VTAPE R11.5                             RECYCLE PHYSICAL BACKSTORE VOLUMES                                         COMMAND AND INPUT PARAMETER SYNTAX CHECK SYNTAX CHECK: ....+....1....+....2....+....3....+....4....+....4....+....5....+....6....+....7.. * (COMMENTS CONTAIN AN ASTERISK IN COLUMN#1) * SETUP ENVIRONMENT * SET DEBUG             (OPT)  DEBUG MODE (DIAGNOSTIC INFORMATION)  * SET UNITRETENTION     (OPT)  UNIT RETENTION FOR MANUAL CARTRIDGE  *                              LOADER (UNATTENDED) OPERATION OR     *                              ALLOCATE SAME INPUT UNIT ADDRESS     *                              FOR ALL INPUT BACKSTORE VOLUMES      *SET MOUNTTIMEOUT(0-999) (OPT) RECYCLE MOUNT MONITOR TIMEOUT        *SET MTO(0-999)          (OPT) RECYCLE MOUNT MONITOR TIMEOUT ALIAS  *                              VALUE FOR INPUT BACKSTORE VOLUMES    *                              VALUE: 0     = DEFAULT     (OFF)     *                                     1-999 = TIMER VALUE           *                                             IN MINUTES  (ON)      *SET TAPECONSOLIDATIONRATIO(0-9) (OPT) RECYCLE TAPE CONSOLIDATION   *                                      RATIO                        *SET TCR(0-9)                    (OPT) RECYCLE TAPE CONSOLIDATION   *                                      RATIO ALIAS                  *                              VALUE: 0     = TURN OFF TCR (OFF)    *                                     1     = DEFAULT      (ON)     *                                     1-9   = TCR VALUES   (ON)      SET MODE(LIVE),       (OPT)  SIMULATE|LIVE|SYNTAX CHECK       LINECOUNT(60),    (OPT)  MAX LINES PER PAGE       CART3480(00800),  (OPT)  DEFINE DEFAULT CARTRIDGE SIZES       CART3490(02400),  (OPT)  IN MEGABYTES FOR 3480, 3490 & MAGSTAR       CART3590(40000),  (OPT)  *                                          MOUNTTIMEOUT(0),  (OPT)  RECYCLE MOUNT TIMEOUT                      TAPECONSOLIDATIONRATIO(3) (OPT) TAPE CONSOLIDATION RATIO      * SET MODE(SYNTAX)      (OPT)  ONLY PERFORM A CC SYNTAX CHECK * YOU CAN OPTIONALLY CONTROL WHICH REPORTS ARE PRODUCED BY THE * RECYCLE PROCESS USING THE REPORT CONTROL CARD:  *   REPORT CANDIDATE(ALL),   (OPT)  LIST DETAIL|SUMMARY|ALL DATA SETS          SELECTED(ALL),    (OPT)  LIST DETAIL|SUMMARY|ALL DATA SETS          PROCESSED(DETAIL) (OPT)  LIST DETAIL|SUMMARY|ALL DATA SETS * RUN A RECYCLE FOR GROUP# 61 PRIMARY (EXAMPLE)     RECYCLE GROUP(61),      (REQ)  GROUP           SUBGROUP(*),    (OPT)  SUBGROUP *=ALL, S|M|L           SOURCE(PRI),    (OPT)  INP VOLUMES PRIMARY|DUPLEX           TARGET(PRI),    (OPT)  OUT VOLUMES PRIMARY|DUPLEX|BOTH           PERCENT(50),    (OPT)  MAX VOLUME % USED TO SELECT           MAXVOLS(1000),  (OPT)  MAX # VOLUMES TO SELECT           DEVTYPE(*),     (OPT)  SELECT 3480,3490,3590, *=ALL           PRIORITY(LMS),  (OPT)  SELECTION PRIORITY           TAPECONSOLIDATIONRATIO(5) (OPT) TAPE CONSOLIDATION RATIO
 SYNTAX CHECK: ....+....1....+....2....+....3....+....4....+....4....+....5....+....6....+....7..   * RUN A RECYCLE FOR GROUP# 62 DUPLEX  (EXAMPLE)                         *        RECYCLE GROUP(62),      (REQ)  GROUP                                            SUBGROUP(*),    (OPT)  SUBGROUP *=ALL, S|M|L                        SOURCE(PRI),    (OPT)  INP VOLUMES PRIMARY|DUPLEX                   TARGET(BOTH),   (OPT)  OUP VOLSMES PRIMARY|DUPLEX|BOTH|*            PERCENT(300),   (OPT)  MAX VOLUME % USED TO SELECT                  MAXVOLS(100),   (OPT)  MAX # VOLUMES TO SELECT                      DEVTYPE(*),     (OPT)  SELECT 3480,3490,3590, *=ALL                 PRIORITY(LMS)   (OPT)  SELECTION PRIORITY                 * RECYCLE MORE GROUPS OR INDIVIDUAL PHYSICAL TAPES AS NEEDED >END OF INPUT< 4 COMMAND(S) ANALYZED, NO ERRORS DETECTED, PROCESSING BEGINS.
Example 2 of the SVTRC100 report
RECYCLE.SVTRC100    CA11.SVT2                           CA VTAPE                       HH:MM:SS mm/dd/yy  PAGE#     3 CA VTAPE R11.5                             RECYCLE PHYSICAL BACKSTORE VOLUMES                                                 COMMAND PROCESSOR REPORT  REASON   CODE    COMMAND     OPTIONS                                         MESSAGES                                 PAGE# --------  ----------  ----------------------------------------------  ---------------------------------------- -----           SET         MODE(LIVE),DEBUG(N),UNITRETENTION(N),                       MOUNTTIMEOUT(0),LINECOUNT(60),                       TAPECONSOLIDATIONRATIO(3:1),                       CART3480(800),CART3490(2400),CART3590(40000)           REPORT      CANDIDATE(ALL),SELECTED(ALL),PROCESSED(DETAIL) SVTSZ197I PERCENT IGNORED WHEN INCLUDE VOLUME LIST DEFINED SVTSZ198I MAXVOLS IGNORED WHEN INCLUDE VOLUME LIST DEFINED           RECYCLE     GROUP(61),SUBGROUP(*),PRIORITY(LMS),                                                          1                       SOURCE(PRIMARY),PERCENT(999999),DEVTYPE(*),                       TARGET(PRIMARY),MAXVOLS(999999),                       TAPECONSOLIDATIONRATIO(5:1) SVTSZ197I PERCENT IGNORED WHEN INCLUDE VOLUME LIST DEFINED SVTSZ198I MAXVOLS IGNORED WHEN INCLUDE VOLUME LIST DEFINED 00000004  RECYCLE     GROUP(62),SUBGROUP(*),PRIORITY(LMS),            PROJECTED TCR LOWER THAN REQUESTED TCR       13                       SOURCE(PRIMARY),PERCENT(999999),DEVTYPE(*),                       TARGET(BOTH),MAXVOLS(999999),                       TAPECONSOLIDATIONRATIO(3:1)
