Previous Topic: Using the Main MenuNext Topic: Cache Management and Scratch Pool Header Information
Using the Group Display Panel
By selecting option 1 from the Main Menu, information about the CA Vtape Externalization groups is displayed. These groups control whether Virtual Volumes are compressed when written to the DASD buffer and how they are Externalized to physical tape.
The following panel will be displayed:
Menu  Functions  Confirm  Utilities  Help      File  Help                     CA Vtape Group Display                 Row 1 to 13 of 32  Command ===>       Line Commands: D=Detail S=Subgroups                                    Q=Externalization Queue   Display of defined Groups.           Max Drives:  5    In Use:  0    Grp W Loc  Vol  Comp       ----- Backstore Unit ----- --- Sub Group ----    ID# Q Rmt Pool# OPT        Primary  Duplex   Exp/Tri  Short   Med   Long  _   1 N Loc    1   N         T10PF    T10PF                15    60    >60  _   2 N Loc    1   N         T10PF    T10PF                15    60    >60  _   3 N Loc    1   N         T10PF             3490        15    60    >60  _   4 N Loc    1   N         T10PF    T10PF    3490        15    60    >60  _  11 N Loc    1   N         T10PF                         30    60    >60  _  12 N Loc    1   N         T10PF    T10PF                30    60    >60  _  13 N Loc    1   N         T10PF             3490        30    60    >60  _  14 N Loc    1   N         T10PF    T10PF    3490        30    60    >60  _  21 N Loc    1   N         T10PF                          7    60    >60  _  22 N Loc    1   N         T10PF    T10PF                 7    60    >60  _  23 N Loc    1   N         T10PF             3490         7    60    >60  _  24 N Loc    1   N         T10PF    T10PF    3490         7    60    >60  _  31 N Loc    1   N         SL859840                       0     7     >7
The information shown includes the following:
Max Drives
Maximum number of drives that the Backstore Engine can use concurrently.
In Use
Number of drives currently in use.
MAX USS
Maximum number of UNIX files that the Backstore Engine can use concurrently.
In Use
Number of UNIX files currently in use.
Grp ID#
Group number.
WQ
Whether or not work is presently queued for Externalization.
Loc Rmt
Indicates whether the Group is defined for local or remote (P2P) use.
Vol Pool#
Shows the assigned Volume Pool definition for the Group.
Comp Opt
Displays the HardwareCompressionOption parmlib attribute setting. Options are as follows:
Y
Yes (compression is active).
N
No (compression is not active).
JCL
The TRTCH parameter in your JCL or the default drive setting determines whether compression is used (compression is optional).
Primary
Device type or esoteric to use when creating a primary tape.
Duplex
Device type or esoteric to use when creating a duplex tape.
Exp/Tri
Device type or esoteric to use when creating the Export tape or USS when creating a Triplex copy.
Sub Group
Groups are broken down into three subgroups based on the ShortRetention, MediumRetention, CatalogControlSubgroup, NeverExpireSubgroup, and SpecialRetention parmilb attributes. The values for the ShortRetention and MediumRetention attributes are displayed. Options are as follows:
Short
Expiration dates less than or equal to this number of days.
Medium
Expiration dates greater than the Short number of days and less than or equal to this number of days.
Long
Expiration dates greater than the Medium number of days.
You can issue the following line commands in this panel:
D
Shows another panel listing the parmlib attributes defined for the selected Group.
Q
Shows another panel listing the Virtual Volumes waiting to be Externalized in the subgroup queues for this group.
S
Shows another panel listing the partially full Backstore Tapes used for this group that Externalization will remount for filling.
