Previous Topic: ISPF InterfaceNext Topic: Using the Group Display Panel
Using the Main Menu
To start the CA Vtape ISPF Interface, execute the SVTSMON member from the CCUUEXEC library.
The Main Menu displays as follows:
---------------------------   CA Vtape   ---------------------      Subsystem ID......... SVT1  (SVTn, where n is 1-8)      Select one of the following:      1  Group List         Display output group information      2  Tape Devices       Display SVTS related tape devices      3  Virtual Volumes    Manage virtual volumes      4  Dataset List       Manage the dataset filter list      5  Dataclass List     Manage the Dataclass filter list      Enter PF3 to exit   Option ===>
From the Main Menu, you can select the following items:
1 Group List
Shows information about the CA Vtape Externalization subgroup queues.
2 Tape Device
Shows information about the Virtual Tape Devices and physical tape drives in use by CA Vtape.
3 Virtual Volumes
Shows information about Virtual Volumes.
4 Dataset List
Shows information that you can use to display and manage the data set list filters. This option is deactivated when you use the parmlib-based enhanced filters.
5 Dataclass List
Shows information that you can use to display and manage the data class entries. This option is deactivated when you use the parmlib-based enhanced filters.
