Previous Topic: GENERATE=VOLUMEPOOLSNext Topic: INITIALIZE=GLOBAL
INITIALIZE=BSDS1
This command is used when running the SVTSUTIL program to initialize a BSDS during the product verification process, or when recreating a BSDS in a recovery situation.
Syntax
INITIALIZE=BSDS1,NUMBER_OF_VOLUMES=nnnnnnnn
Where nnnnnnnn is the number of Virtual Volumes the BSDS should be sized for.
Sample JCL was generated by the Customization Panels and can be found in PREFIX.SVTJCL(GLOBAL).
Note: Volume Pooling will be required if the NUMBER_OF_VOLUMES is greater than 510,800 Virtual Volumes.
