This command is used when executing the SVTSUTIL program to create an SVTS VTPOOLS parameter library member from the active GLOBAL VCAT assigned to the Subsystem defined by the specified utility JCL SVTS parameter.
This command is used to create a customized VTPOOLS member for the first time, to recreate a lost or corrupted VTPOOLS member, or to audit your current VTPOOLS member by generating a new member from the VOLSER ranges and pool definitions currently in use in the Global VCAT.
GENERATE=VOLUMEPOOLS
Sample JCL can be found in HLQ.CCUUJCL(GENVOLPL).
