Report SVTRC125.B lists the candidate Virtual Volumes sorted by subgroup, physical VOLSER, and physical VOLSER file sequence number. These are the Virtual Volumes available for input selection processing after excluding any physical volumes defined by a Physical Volume Exclusion List (PEXCLUDE DD defined in the RECYCLE JCL). Only volumes for the group and subgroup or subgroups specified by the RECYCLE command are listed. If multiple RECYCLE commands are coded, a report will be produced for each command.
Example of the SVTRC125.B report
RECYCLE.SVTRC125.B CA11.SVT2 CA VTAPE HH:MM:SS mm/dd/yy PAGE# 3 CA VTAPE R11.5 CANDIDATE VIRTUAL VOLUME FILES GROUP# 61 SORTED BY SUBGROUP, PHYSICAL VOLSER AND FILE SEQUENCE VIRTUAL DSN PHYSICAL FILE ESTIMATED GROUP SUB VOLSER SEQ VOLSER SEQ# #MB.USED PHYSICAL FILENAME REF# ----- --- ------ --- ------ ------ -------- -------------------------------------------- -------- 61 S 101565 P 541069 1 8 QAPROD.VVE.V101565.PRIMARY 1 61 S 101566 P 541069 2 8 QAPROD.VVE.V101566.PRIMARY 2 61 S 101568 P 541069 3 8 QAPROD.VVE.V101568.PRIMARY 3 61 S 101572 P 541125 1 8 QAPROD.VVE.V101572.PRIMARY 4 61 S 101574 P 541125 2 8 QAPROD.VVE.V101574.PRIMARY 5 61 S 101577 P 541125 3 8 QAPROD.VVE.V101577.PRIMARY 6 61 S 101579 P 541126 1 8 QAPROD.VVE.V101579.PRIMARY 7 61 S 101581 P 541126 2 8 QAPROD.VVE.V101581.PRIMARY 8 61 S 101583 P 541126 3 8 QAPROD.VVE.V101583.PRIMARY 9 61 S 101585 P 541132 1 8 QAPROD.VVE.V101585.PRIMARY 10 61 S 101587 P 541132 2 8 QAPROD.VVE.V101587.PRIMARY 11 61 S 101589 P 541132 3 8 QAPROD.VVE.V101589.PRIMARY 12 61 S 101591 P 541147 1 8 QAPROD.VVE.V101591.PRIMARY 13 61 S 101593 P 541147 2 8 QAPROD.VVE.V101593.PRIMARY 14 61 S 101595 P 541147 3 8 QAPROD.VVE.V101595.PRIMARY 15 61 S 101597 P 541148 1 8 QAPROD.VVE.V101597.PRIMARY 16 61 S 101599 P 541148 2 8 QAPROD.VVE.V101599.PRIMARY 17 61 S 101601 P 541148 3 8 QAPROD.VVE.V101601.PRIMARY 18
