Previous Topic: Candidate Virtual Volume FilesNext Topic: Sorted by Subgroup, Physical VOLSER and File Sequence
Sorted by Physical Filename
Report SVTRC125.A lists the candidate Virtual Volumes sorted in ascending physical filename sequence. These are the Virtual Volumes available for input selection processing after excluding any physical volumes defined by a Physical Volume Exclusion List (PEXCLUDE DD defined in the RECYCLE JCL). Only volumes for the group and subgroup or subgroups specified by the RECYCLE command are listed. If multiple RECYCLE commands are coded, a report will be produced for each command.
Example of the SVTRC125.A report
RECYCLE.SVTRC125.A  CA11.SVT2                           CA VTAPE                       HH:MM:SS mm/dd/yy  PAGE#     4 A VTAPE R11.5                               CANDIDATE VIRTUAL VOLUME FILES GROUP# 61                                     SORTED BY PHYSICAL FILENAME          VIRTUAL DSN PHYSICAL  FILE ESTIMATE GROUP SUB VOLSER SEQ VOLSER    SEQ#  #MB.USED  PHYSICAL FILENAME                                                   REF# ----- --- ------ --- ------  ------  --------  --------------------------------------------                    --------    61  S  101565 P   541284       1         8  QAPROD.VVE.V101565.PRIMARY                                            21    61  S  101566 P   541284       2         8  QAPROD.VVE.V101566.PRIMARY                                            22    61  S  101568 P   541284       3         8  QAPROD.VVE.V101568.PRIMARY                                            23    61  S  101572 P   541284       4         8  QAPROD.VVE.V101572.PRIMARY                                            24    61  S  101574 P   541284       5         8  QAPROD.VVE.V101574.PRIMARY                                            25    61  S  101577 P   541284       6         8  QAPROD.VVE.V101577.PRIMARY                                            26    61  S  101579 P   541284       7         8  QAPROD.VVE.V101579.PRIMARY                                            27    61  S  101581 P   541284       8         8  QAPROD.VVE.V101581.PRIMARY                                            28    61  S  101583 P   541284       9         8  QAPROD.VVE.V101583.PRIMARY                                            29    61  S  101585 P   541284      10         8  QAPROD.VVE.V101585.PRIMARY                                            30    61  S  101587 P   541284      11         8  QAPROD.VVE.V101587.PRIMARY                                            31    61  S  101589 P   541284      12         8  QAPROD.VVE.V101589.PRIMARY                                            32    61  S  101591 P   541284      13         8  QAPROD.VVE.V101591.PRIMARY                                            33    61  S  101593 P   541284      14         8  QAPROD.VVE.V101593.PRIMARY                                            34    61  S  101595 P   541284      15         8  QAPROD.VVE.V101595.PRIMARY                                            35    61  S  101597 P   541284      16         8  QAPROD.VVE.V101597.PRIMARY                                            36    61  S  101599 P   541284      17         8  QAPROD.VVE.V101599.PRIMARY                                            37    61  S  101601 P   541284      18         8  QAPROD.VVE.V101601.PRIMARY                                            38    61  S  101602 P   541202       1         8  QAPROD.VVE.V101602.PRIMARY                                            16    61  S  101603 P   541202       2         8  QAPROD.VVE.V101603.PRIMARY                                            17    61  S  101739 P   541202       3         8  QAPROD.VVE.V101739.PRIMARY                                            18    61  S  101740 P   541202       4         8  QAPROD.VVE.V101740.PRIMARY                                            19    61  S  101741 P   541202       5         8  QAPROD.VVE.V101741.PRIMARY                                            20    61  S  101744 P   540336       1         8  QAPROD.VVE.V101744.PRIMARY                                             1    61  S  101745 P   540336       2         8  QAPROD.VVE.V101745.PRIMARY                                             2    61  S  101746 P   540336       3         8  QAPROD.VVE.V101746.PRIMARY                                             3    61  S  101747 P   540476       1         8  QAPROD.VVE.V101747.PRIMARY                                             4    61  S  101748 P   540476       2         8  QAPROD.VVE.V101748.PRIMARY                                             5    61  S  101750 P   540476       3         8  QAPROD.VVE.V101750.PRIMARY                                             6    61  S  101751 P   540520       1         8  QAPROD.VVE.V101751.PRIMARY                                             7    61  S  101752 P   540520       2         8  QAPROD.VVE.V101752.PRIMARY                                             8    61  S  101753 P   540520       3         8  QAPROD.VVE.V101753.PRIMARY                                             9    61  S  101754 P   540562       1         8  QAPROD.VVE.V101754.PRIMARY                                            10    61  S  101756 P   540562       2         8  QAPROD.VVE.V101756.PRIMARY                                            11    61  S  101758 P   540562       3         8  QAPROD.VVE.V101758.PRIMARY                                            12    61  S  101759 P   540692       1         8  QAPROD.VVE.V101759.PRIMARY                                            13    61  S  101760 P   540692       2         8  QAPROD.VVE.V101760.PRIMARY                                            14    61  S  101761 P   540692       3         8  QAPROD.VVE.V101761.PRIMARY                                            15
