To view the Detail Scratch Virtual Volume Report, remove the DUMMY from the optional FILEOUT DD. You can also edit the CA Vtape CA Earl member ERPT0301 in the CA Vtape CCUUEARL library and uncommenting the Detail Scratch Virtual Volume Report lines. The report contains a list of VOLSERs in scratch status in the Global VCAT. If a VOLSER has write protection on, Write Protected appears next to the VOLSER.
Example of editing the CA Vtape CCUUEARL library member ERPT0301:
*************************************************************** * =====>> Detail Scratch Virtual Volume Report <<===== * * To generate a Detail Scratch Virtual Volume Report, * * remove the '!' comment characters from the following * * 7 lines (do not remove any '!*' lines). * *************************************************************** REPORT COPY ERPTHDR USING 'ERPT0301' TITLE @ 39 'S C R A T C H V I R T U A L V O L U M E R E P O R T' TITLE 'Report Detail' TITLE ' ' PRINT @2 RECORD_OUT
Example of the Detail Scratch Virtual Volume report
DD/MM/YY CA Vtape r12.6 PAGE 1 HH.MM.SS ERPT0301 All Rights Reserved S C R A T C H V I R T U A L V O L U M E R E P O R T Report Detail ------------------------------------------------------------------------------------------------------------------------------------ Volume Serial ------------------------------------------------------------------------------------------------------------------------------------ 100000 100001 100002 Write Protected 100003 100004 100005 100006
