This report lists the following:
The Available in Scratch Pool report line is the total number of scratch volumes residing in the scratch pool. The value indicates the number of scratch volumes available with one exception. If Virtual Volumes were write protected at the pool level (SVTn SET WRITPROT,ON,VVP=vvvvnn) then these volumes are included in this total. If Virtual Volumes were write protected at the volume level (SVTn SET WRITPROT,ON,VVE= vvvvvv) then the volumes are not included in this total.
The Available in Scratch Pool value is printed as asterisks (*********) if the GLOBAL or VCAT DD statements are not defined, or they reference the wrong Global VCAT or Local VCAT.
The Virtual Volumes in Write Protect report line indicates the number of Scratch Virtual Volumes with write protection turned on. Scratch Virtual Volumes that are write protected cannot be written to so they cannot be used as scratch tapes. To make these VOLSERs available for use as scratch tapes, you must use the SVTn SET WRITPROT console command to turn off write protection.
Note: For details on printing a list of write protected VOLSERs, see Obtain the Optional ERPT0301 Detail Scratch Virtual Volume Report.
The Virtual Volumes in Scratch Status report line is the total number of Virtual Volumes that are marked as scratch volumes. This value includes volumes that are marked with the write protect flag and volumes that are not marked with the write protect flag.
Example of the Summary Scratch Virtual Volume report
Summary Scratch Virtual Volume Report DD/MM/YY CA Vtape r12.6 PAGE 1 HH.MM.SS ERPT0301 All Rights Reserved S C R A T C H V I R T U A L V O L U M E R E P O R T Report Summary GRAND TOTAL Available in Scratch Pool = 5235 Virtual Volumes in Write Protect = 21 Virtual Volumes in Scratch Status = 5256 Note: - Write Protect Scratch Virtual Volumes are not available for mount processing unless Write Protect flag is turned off (refer to SVTn SET WRITPROT command).
