Previous Topic: Status OutputNext Topic: Application of SUBACID
SUBACID—Batch Job ACIDs
Valid on z/OS.
Use the SUBACID control option to indicate how CA Top Secret derives an ACID for batch jobs that are submitted by the following methods:
All entry methods are accepted.
SUBACID(J|U,n)
SUBACID(J,n)
Indicates that the first n characters of the jobname parameter on the job card is used as the ACID, unless USER=acid is present.
Specifying SUBACID(J,7) restricts jobnames to the user's userid plus one character. This will occur unless the user is explicitly PERMITted to submit other ACIDS.
SUBACID(U,n)
Indicates that the first n characters of the logged on user's ACID, or of the ACID associated with the started task, is used as the ACID for the batch job.
Default: SUBACID(U,7).
