The output of the TSS MODIFY(STATUS) command has headers in both upper and mixed case. Any header in mixed case denotes information not set by a control option but rather derived from the system.
The following details status values returned in the STATUS field:
Connection to the remote node is active.
Connection to the remote node is inactive.
The Journal file on the remote node has been defined.
The Journal file on the remote node has not been defined.
No commands have been sent to the remote nodes yet. After the first is sent, PRE50 will no longer appear.
Indicates attempts are being made to re‑establish the connection to the remote node.
