Previous Topic: SMA—Start SMA DynamicallyNext Topic: ST—Control Option Display
SMFTYPE—Change SMF Record Type
Use the SMFTYPE control option to change the SMF record type for SAF trace records from 231 to another type.
All entry methods are accepted
SMFTYPE(nnn)
nnn
Specifies the SMF record type to be used for SAF trace records.
Range: 0 to 255
IBM Reserved: 0 to 12
Available for user-written records: 128 to 255
