Previous Topic: Example: SHUTDOWNNext Topic: SMFTYPE—Change SMF Record Type
SMA—Start SMA Dynamically
Valid on z/OS.
Use the SMA control option for the TSSSMA address space to start dynamically and establish communication with the remote SMA host defined in the NDT SMANODE record.
This control option is specified in the startup JCL parameters file or dynamically issued with the TSS MODIFY command.
SMA (ON|OFF)
