Previous Topic: GOSETGID—SAF Callable ServiceNext Topic: HFSSEC—HFS Security On or Off
HFSACL—HFS File System
Valid on z/OS.
Use the HFSACL control option to use Access Control Lists (ACLs). ACLs provide more control over the HFS file system than native HFS security.
When HFSACL is activated, Access Control Lists (ACLs) are used in the z/OS UNIX security access validation process in addition to the checking of file permission bits and superuser status. When HFSACL is not activated, normal z/OS UNIX security access validation is done, including the checking of file permission bits and superuser status. ACLs are supported in z/OS release 1.3 and above. If HFSSEC is enabled, ACLs are not used regardless of the setting of this field.
TSS MODIFY HFSACL(ON|OFF)
ON
HFSACL is activated.
OFF
(Default) HFSACL is deactivated.
