Previous Topic: User FacilitiesNext Topic: HFSACL—HFS File System
GOSETGID—SAF Callable Service
Valid on z/OS.
Use the GOSETGID (Group Owner SETGID) control option to alter the way the makeFSP SAF callable service works. When GOSETGID is set and a new directory is created, the new directory inherits the S_ISGID setting from the parent directory. Otherwise, the bit is set to zero.
When a file or directory is created the owning GID of the new file is normally set to the parent directory setting. When GOSETGID is set and the parent's set—gid bit is off, then the owning GID of the new file or directory is set to the effective GID of the process.
TSS MODIFY(GOSETGID(ON|OFF))
ON
Activated.
OFF
(Default) Deactivated.
