Previous Topic: Responding to User RequestsNext Topic: View Information About an Active Request
Monitor Requests
A production user with sufficient permissions, can use the Start Request panel in the Operations tab to monitor, or control requests. In the Start Request panel, view the active requests for a particular start request form in a folder, and submit the new requests. The requests list displays the history and status of tasks that the current user started, and any tasks to which the user has List permission.
When a start request form is started form the Library Browser or from the Operations tab, the instance state depends on the following criteria:
The Current option button displays the queued, running, completed, aborting, and failed tasks. The length of time a completed tasks remains in this list depends on the policies settings in the Orchestrator configuration pages. For each request, columns in the requests list pane show the request ID, the current state of the request, the start time, and end time. You can filter by state to view the requests of a particular state.
The Archived option button lets you view the failed and completed instances.
You can do the following actions when you select single start request forms in different states:
When you select multiple instances of the start request forms in different states, the Open and Properties options are disabled. Depending on the state of selected instances, the Abort and Dequeue options are enabled.
Depending on the state of selected instances, you can take the following actions:
You can view the running, queued, and other recently submitted requests in the Start Requests link in the Links panel. If the current user is logged on as a content administrator, the request list displays the history and status for that tasks that all the user starts.
