Previous Topic: Monitor RequestsNext Topic: Open an Instance of a Process that is in the Start Request Form
View Information About an Active Request
You can view information for an active request by right-clicking an instance, and then click Properties. The Queue Properties dialog displays the request information.
The fields on the Queue Properties tab of the Queue Properties dialog are updated to show the status of the request each time you open it.
If a request has output parameters, the Queue Properties dialog displays the parameters and their values as the process control is processed. Some parameters can show an initial input value and then change after the task changes their values. Other parameters can be used only for output and display a value until the task assigns output values to them.
