If you do not routinely purge the CA Process Automation Reporting database, this database continues to grow.
Important! When CA Process Automation attempts to add data to a full Reporting database, that data is lost. If the Reporting database is not isolated from other CA Process Automation databases, a full database can cause CA Process Automation to stop working. If other applications share the Reporting database server space, the outage could extend beyond CA Process Automation.
If you require reporting data to be retained for compliance with regulations, back up the reporting data and move your backup to a secure location. Then, purge the reporting database. Purging the database prevents the loss of data that is caused by attempting to add data to a full database.
Administrators can purge reporting data on demand or on a configured schedule.
Click the Delete Reporting Data button and specify a date range for the reporting data to delete.
Copyright © 2014 CA.
