Previous Topic: Share and Unshare ReportsNext Topic: Administering the Reporting Database
Delete Report
You can permanently delete reports that are no longer needed. You need sufficient permissions to delete reports.
Note: Only a content administrator has permission to delete the predefined.
  1. Right-click a report from the reporting panel that you want to delete.
  2. Select Delete form the pop-up menu and confirm your deletion.
    The report is deleted.
Note: To delete multiple reports, select check boxes next to reports to select multiple reports from the report list and click Delete from toolbar.
