The Content Packages palette in the Operations tab lets you monitor automation objects available in a content package. A content designer adds the required automation objects to a folder and exports it as a content package. You can view all the imported content packages and their objects in the Content Packages palette. You cannot edit any automation objects in the Content Packages palette.
For more information about content packages, see the Content Designer Guide.
This section contains the following topics:
View and manage the objects that are imported in a content package. You can sort by filters to view the object instances.
You can view the object states and the other related information in the right-hand pane.
Copyright © 2014 CA.
