Previous Topic: Monitor Active SchedulesNext Topic: Working with Content Packages
Global Schedules
Global Schedules tab in the Links palette displays runtime tasks that are scheduled on an Orchestrator, Touchpoints, and on all the nodes. The global schedule displays the following information for each task:
Task
The name of the task.
Start Time
The start time for a task.
End Time
The time the task ends.
State
The current state of the task.
Type
The type of operation that the task schedules.
Calendar
The Calendar parameter that is specified for the task.
Exclude
The vacation calendar specified for the task.
Scheduled Time
The time at which the task was scheduled to start.
Schedule
Specifies the path of the schedule object.
Content Package Name
The name of the content package to which the object belongs (if the object was imported in a content package).
Content Package Release Version
The release version of the content package (not of the specific object), if the object was imported in a content package.
The following procedure describes how a content administrator manages the global schedules in the Operations tab.
  1. Log in to CA Process Automation.
  2. In the Operations tab, click Links.
  3. Click Global Schedules.
    The Global Schedules pane lists the runtime tasks that are scheduled on all the nodes.
  4. You can filter to view the tasks that are based on the start date, running on Orchestrator or Touchpoints.
  5. Right click a task, the following option appears:
    Reset
    Resets the start time and the task state changes to the default On hold state.
    Release Hold
    Release the task that is in On hold state and the task state changes to Idle.
    On Hold
    Keeps a task in On Hold state.
    Dataset
    View system and process information for the task.
    Task Properties
    Lets you change the time, program, and execution settings.
    Time — Provide the start time, end time, frequency to repeat the task at regular intervals.
    Program — Specify the program name that you want to execute on the host computer.
    Execution Settings — Provide the target and the timeout details.
  6. (optional) Select the Archived option button to view the archived tasks.
Start Requests
Start Requests in the Links palette displays the runtime instances of start requests on the Orchestrator. The Start Requests displays the following information for each start request:
Instance
Specifies the start request name.
Process Instance
Specifies the process instance name.
Scheduled Time
Specifies the scheduled time.
State
Specifies the current state of the start request. Queued, Running, Failed, and Completed are the available states and you can filter to view to the start request of required states.
Start Time
Specifies the time when the start request instance was started.
End Time
Specifies when the instance got completed or failed or aborted.
User
Specifies the user.
