The DB views return the following columns that you can use to generate the user-defined reports:
The Process_Instances View contains the following columns:
Displays the criticality level of a process instance.
Displays the duration of a process in seconds.
Displays the time at which the process instance ended.
Indicates the expected duration for a process.
Valid Values: Days, Hours, and Minutes
Displays the instance name of the running process instance.
Defines the ID of an instance.
Displays the baseline manual cost for each hour.
Displays the manual run time (in minutes).
Defines the ID of the Orchestrator where the process is running.
Defines an organization group name in support of multi-tenancy environments.
Defines an organization id or name in support of multi-tenancy environments.
Defines the ID of the parent process. If the parent process is not triggered by another process, it returns a NULL value.
Indicates the location of the process in the library.
Indicates the version of the process.
Indicates the status of the runtime process instance for which the duration is defined.
Displays progress of a process.
Displays the identifier of a row.
Defines the ID of the root instance that is triggered independently.
Displays the time at which the process instance started.
Defines the state of the process.
Displays the name of an application or a system group.
Displays the name of the user who started the process.
Indicates how long before a process exceeds the expected duration to warn the user.
The Automation_Objects View contains the following columns:
Specifies the location of the Automation Object in the library.
Specifies the version of the Automation Object.
Specifies the type of the Automation Object created.
Identifies the user who created the Automation Object.
Specifies the tags that are assigned to the Automation Object.
Indicates the date on which the Automation Object was created.
Indicates the date on which the Automation Object was last modified.
The Operator_Instances View contains the following columns:
Specifies the operator instance.
Displays the module name to which operator belongs.
Displays the time at which the operator instance started.
Displays the name of the operator.
Displays the time at which the operator instance ended.
Copyright © 2014 CA.
