The database views (DB Views) reside in the reporting database that you provided during domain installation. Use the following DB views to generate user-defined reports:
Provides information about the run-time instances.
Provides information about the automation objects created in the library.
Provides information about the operator instances, which the Orchestrator uses to monitor operators.
Note: As a prerequisite, grant user permissions to create DB Views in MySQL Server. For more information, see Add Permissions to create DB Views.
Copyright © 2014 CA.
