Use the product to view and download the following predefined reports:
Reports the referred objects by category. The report list the objects for example, resources, interactive request forms, custom operators that a process refer. The reports lists what objects, and where the objects are referred in CA Process Automation.
Reports the processes that are completed.
Reports the state of the executed processes. The process states are as follows:
Reports the execution time of the processes.
Reports the Return on Investments graph.
Note: To view the Return on Investment (ROI) reports, select the Enable ROI check box in the Library Object Properties.
Reports the time saved due to CA Process Automation when compared to a manual process.
Concurrent Processes Report
Reports the average number of concurrent process instances that are running on an Orchestrator.
Reports the expected duration status for processes. The expected duration is the interval in which a process is expected to run
Note: By default, the predefined reports are shared to all users.
Copyright © 2014 CA.
