Previous Topic: Working with Predefined ReportsNext Topic: Working with Your Custom Reports
View BIRT Report
You can view BIRT Reports.
  1. Log in to the CA Process Automation web interface and select the Reports tab.
  2. On the All Reports pane, Right-click a report and select View.
    The BIRT Report Viewer window opens. You can set filtering criteria in the Parameter window to view the reports.
