When recovering a process, CA Process Automation resets the operators in System_Error that executed on the Orchestrator, Touchpoint, or Host Group being recovered, and then resumes the entire process. When resetting operators in System_Error within a process, CA Process Automation proceeds as follows:
If the Process instance is currently in ... lane |
CA Process Automation resets System_Error Operators in ... lanes |
Notes |
Main |
Main |
The Lane Change Handler and Exception Handler lanes are reset upon re-entry. |
Lane Change Handler |
Main Lane Change Handler |
The Exception Handler lane is reset upon re-entry. |
Exception Handler |
Main Lane Change Handler Exception Handler |
Note: CA Process Automation exits an Exception Handler lane and a Lane Change Handler lane when there are no more operators to execute, even if some of the operators are in System_Error.
Copyright © 2014 CA.
