Previous Topic: Install NGINXNext Topic: Basic Communication
Copy the Configuration Templates
Once NGINX is installed, extract the template files from the CA Process Automation installation media to your NGINX installation directory.
  1. Navigate to the following folder on the CA Process Automation installation media:
    install_dir/DVD1/NginxConfTemplates
  2. Extract the files from NginxConfig.zip.
  3. Navigate to the pam subfolder. This folder includes the following files:
    pam-server.conf
    Used for non-secure configuration.
    secure-pam-server.conf
    Used for secure configuration.
    pam-rest.conf
    Used for REST configuration.
    These files are specific to CA Process Automation configuration with NGINX.
  4. Copy these three files and paste them into the following folder:
    nginx_install_dir/conf
    You can now configure the NGINX load balancer.
