Previous Topic: PrerequisitesNext Topic: Copy the Configuration Templates
Install NGINX
NGINX is free open source web server software that you can download and install for your operating system. CA Process Automation is certified with NGINX version 1.4.1. Use the following instructions to get started.
Windows
Download the NGINX package and extract the files.
Linux
Note: UNIX and Linux commands for NGINX can vary, depending on your version. See the OS and NGINX documentation if you need more information or for troubleshooting.
  1. Download the NGINX package and extract the files.
  2. Open a command prompt.
  3. Run the following command to install NGINX:
    rpm -ivh nginx-release-rhel-6-0.el6.ngx.noarch.rpm
    wget http://nginx.org/packages/rhel/6/noarch/RPMS/nginx-release-rhel-6-0.el6.ngx.noarch.rpm
    yum install nginx
Note: The preceding commands are for Red Hat Enterprise Linux.
For both Windows and Linux, invoke NGINX using a command prompt.
In Windows, navigate to the NGINX directory location and enter:
nginx.exe
In Linux, enter:
service nginx  start
To verify that NGINX was successfully installed and currently running, access the URL from a browser:
http://hostname:80
