Previous Topic: Prepare a Microsoft SQL Server Database for CA Process AutomationNext Topic: Understand How the JTDS JDBC Driver Is Referenced
Verify that the SQL Server Database Meets CA Process Automation Requirements
The SQL Server that you prepare for CA Process Automation data stores must meet the following requirements:
Examine the configuration file for your SQL Server to verify that your SQL Server meets CA Process Automation requirements.
  1. Navigate to the ConfigurationFile.ini file, which is created in a path similar to the following:
    C:\ Program Files\Microsoft SQL Server\100\Setup Bootstrap\Log\ yyyymmdd_hhmmss
  2. Verify that the security mode setting resembles the following:
    ; The default is Windows Authentication. Use "SQL" for Mixed Mode Authentication.
    SECURITYMODE="SQL"
  3. Verify that the setting for the SQL system administrator account credentials resembles the following:
    ; Windows account(s) to provision as SQL Server system administrators.
    SQLSYSADMINACCOUNTS=".\Administrator"
  4. Verify that the setting for collation resembles the following:
    ; Specifies a Windows collation or an SQL collation to use for the Database Engine.
    SQLCOLLATION="SQL_Latin1_General_CP1_CI_AS"
