Previous Topic: Planning the Locations of Supporting ComponentsNext Topic: About CA Process Automation Data Stores
Database Prerequisites
CA Process Automation requires that you have one or more of the following third-party databases in which CA Process Automation can store and persist its data:
CA Process Automation has three data stores. Each of these data stores can reside in the same database, in different databases of the same type, or in databases of different types on the same or different database servers.
If you do not already have one of these databases, refer to the prerequisites for each before obtaining one. We recommend that this database and CA Process Automation reside on separate hosts.
Follow the guidelines for the type of database you are using for this Orchestrator installation.
