Previous Topic: Make the Bookshelf Available on Orchestrators without Internet AccessNext Topic: Install Drivers for Database Operators
Configure Firewalls for Bi-directional Communication
CA Process Automation components can be accessed through Web clients. See Ports Used by CA Process Automation for details on the ports used by each component in a CA Process Automation system.
You must configure firewalls to allow bi-directional communication. Bi-directional communication is needed between the following component pairs:
If you use local firewalls on Orchestrator or agent hosts, make sure that CA Process Automation executables can listen and connect bi-directionally through the firewall on each host. Some host-based firewall programs (such as Windows Firewall) allow exceptions for executables.
