Previous Topic: Common Properties of Operators in SchedulesNext Topic: Manually Included Dates
Calendar Settings
The Calendar Settings properties let you include dates from a predefined calendar in a schedule.
Include Calendar
Click the calendar icon to select a predefined calendar to include in your schedule.
Exclude Calendar
Click the calendar icon to select a predefined calendar to exclude in your schedule.
Days per Shift
The number of days to shift a scheduled date when the scheduled date falls on a closed date. The shift can be negative or zero. When this value is negative the date shifts forward. When this value is zero, closed dates are simply skipped without rescheduling the task.
No excluded days
Select this check box to only count open days when shifting a scheduled date to avoid a closed date.
Maximum Shift
When an original scheduled date falls on a closed day and the task is rescheduled, the new date could also fall on a closed date. This parameter defines the maximum number of shifts that are allowed.
Only manually selected
When a calendar is not specified in a schedule, CA Process Automation considers the item scheduled every day. The exception is when you select this option. When this option is selected, schedule the run dates (on the Manually Included Dates tab).
