Previous Topic: Create a Content PackageNext Topic: Add Release Information for a Folder
Add Objects to a Folder
Before you export a folder as a content package, populate the folder with objects.
A CA Process Automation release 04.02.00 content package requires all of the objects to export to be in a single folder. In release 04.1.00, you could add objects as shortcuts from different folders to a package for export.
After you add an object, you can use either the Version or the Release Version parameter to set the object version. If you customized the Release Version parameter, set the object version in the Release Version column.
You can set the release version attribute before you add a selected version of each object to a folder. After you add objects to the folder, set the content package release version.
  1. Create a folder.
  2. To open the folder, double-click it in the Library Browser folder pane.
  3. In the toolbar, click New, and then select an object type.
    CA Process Automation creates an object.
  4. Provide a unique name for the object.
Note: You can also cut and paste an object from another folder to your new content package folder.
