Previous Topic: Monitor Active SchedulesNext Topic: Task Management
Monitor All Occurrences of All Scheduled Tasks
You can monitor the scheduled occurrences of all tasks for a specific day. When you configure a task to repeat multiple times daily for multiple days, CA Process Automation tracks each occurrence of the task. For example, if a task repeats every 10 minutes for half an hour (3 occurrences) every day for 1 year, CA Process Automation tracks 1,095 occurrences. Use this procedure to plan for a future date or to view the results of all tasks that were scheduled for a specific past date.
  1. Click the Operations tab.
  2. Expand the Links pane on the Operations page.
  3. Click Global Schedules.
  4. From the toolbar, select an Orchestrator and environment, then click Refresh.
  5. In the Global Schedules table:
    1. In the Preview Date field, select a date in the valid range for the schedule.
    2. From the Nodes drop-down list, select All Nodes or a specific Orchestrator touchpoint.
    3. Select the Current or Archived option.
    4. Click Refresh.
    CA Process Automation evaluates calendar rules and the validity period that is associated with tasks before displaying the appropriate occurrences in the list. If your task repeats, multiple occurrences on the same day are displayed.
  6. To view a read-only Properties window that shows the configuration settings for the scheduled task, double-click the appropriate occurrence.
  7. In the toolbar:
