Previous Topic: Check Out an ObjectNext Topic: Discard Changes to a Checked-Out Object
Save Changes to a Checked-Out Object
Saving the working version of an object prevents you from losing changes as you work. For example, you could inadvertently close the object editor. Saving changes for a checked-out object affects only the working version of the object. A new version of the object is not created and the object is not checked in.
  1. Check out an object.
  2. Edit the working version.
  3. Click Save.
Once changes are saved to the working version, you can close the editor. The object is still checked out. The working version remains editable and continues to reflect your changes as long as it is still checked out. When you open the object again, the application automatically opens the working version.
