Previous Topic: Phase III: Testing and DeploymentNext Topic: Generate the Process Documentation
Test the Process with Related Objects
Testing is essential to deploying the CA Process Automation management package that represents the processes you want to automate. Verify that all components work together as designed before you deploy the content package from the design environment to the production environment.
CA Process Automation has several features for testing processes:
Testing occurs on the following levels:
The entire deployment can pass all tests and can be operational while a specific form is still being redesigned and tested. The following terms reflect this difference:
Periodically retest mission-critical processes that do not run frequently (such as system failovers). Periodic testing verifies that the processes and users stay current and functional in the production environment and prevents incidents from becoming crises.
More information:
Run Processes Interactively
Debug a Process
Simulate Processing of Operators
