Previous Topic: VersionsNext Topic: Set the Object Version as Current or as a Baseline
Understanding Versions
Refer to the following graphics and examples to learn the essential concepts about working with versions.
Symbols:
Icon that indicates an automation object version. Object version.			Icon that indicates an automation object version. Current version.
Icon that indicates an automation object version. Working version.			Icon that indicates a discarded automation object version. Discard working version.
Icon that indicates an automation object version. Open a previous version.		Icon that indicates an automation object is a baseline version. Baseline version.
Icon that indicates an automation object version. Version checked out by user 1.	Icon that indicates an automation object version. Latest version checked out by user 2.
This graphic provides information about working with versions.
Item:
Description:
Typical Versioning Sequence: A new automation object begins at Icon that indicates an automation object version. version 0. The object is checked out as Icon that indicates an automation object version. working version 0, with the option of applying pending changes to the same version 0 or new version 1.
Current Version: In this typical sequence, Icon that indicates an automation object version. working version 0 is checked in as new version 1. The new version is also typically designated as the Icon that indicates an automation object version. current version. The current version is the one that is used when the process actually runs. The original Icon that indicates an automation object version. version 0 is now considered just a backup or archive.
Changes Applied to the Same Version: In this example, Icon that indicates an automation object version. version 2 is checked out multiple times. Each time, the user has elected to apply the changes to the same version rather than create a new one. Although changes were made in Icon that indicates an automation object version. working versions 3(0), 3(i), and 3(ii), the user has decided to group them all together into the same single version. The user cannot go back to view the object in between changes 3(0) and 3(i). No separate version exists to go back to.
Baseline Version: Version 4 has been designated by the user as a Icon that indicates an automation object is a baseline version. baseline version. Any checked-out working version must be checked in as a new version, version 5. When you specify one or more baseline versions, you are essentially locking each version. This practice prevents any modifications to the actual baseline versions. They can only be used as templates or ancestor class objects to facilitate the creation of new versions.
Current, Working, and Open Versions: Icon that indicates an automation object version. current version 5 has three simultaneous branches users might follow. In branch A, its changes are applied as Icon that indicates an automation object version. new and current version 6. In branch B, Icon that indicates an automation object version. working version 5 can be checked in as Icon that indicates an automation object version. new version 6, with Icon that indicates an automation object version. version 5 remaining as the current version. In branch C, the user elects to Icon that indicates an automation object version. open version 5. The user can view the version but cannot save any changes to it.
Multiple Users: While running processes use Icon that indicates an automation object version. current version 6, it is possible for the object to also be checked out to Icon that indicates an automation object version. user 1 with pending changes in Icon that indicates an automation object version. working version 7. While running processes use Icon that indicates an automation object version. current version 6, the latest changes to the object may be made by user 2 and reflected as Icon that indicates an automation object version. latest version 7.
Discard Working Version: The changes to Icon that indicates a discarded automation object version. working version 7 can be discarded. Similar to an Undo Checkout operation, this rolls back the object to the last checked in version.
New Current Version: The Icon that indicates an automation object version. latest version 7 can be checked out as Icon that indicates an automation object version. working version 7. During check-in, the user can elect to make it the new Icon that indicates an automation object version. current version 8.
