Previous Topic: Datasets PaletteNext Topic: Resources Palette
Process Watch
The Process Watch palette lets you define and monitor the selected automation objects in CA Process Automation.
Start
When you right-click the a process in the Process Watch palette and select Start Process, the process instance that you started appears in the right pane.
Start Suspended
You can start an instance of a process in a suspended state to achieve any of the following objectives:
