Previous Topic: Operations TabNext Topic: Process Watch
Datasets Palette
The Dataset palette lets you view, edit, and add variables in process or operator datasets. See the Production User Guide for instructions.
Each dataset has an expandable list of defined parameters in the right-hand pane that displays the parameters name and value.
Value
When you double-click the Value field of a parameter, you can edit and save the parameter.
View Expression
When you right-click a dataset row, you can select View Expression to get an expression for that variable to use in process definitions.
Add Indexed value
When you right-click a parameter and select Add Indexed value, a new indexed field value is added to the array.
Delete Indexed value
When you right-click a parameter, you can select Delete Indexed Value and confirm the deletion.
