Previous Topic: Properties: EnvironmentNext Topic: Properties: Orchestrator Host
Properties: Host Group
Properties for a selected Host Groups are defined with the following fields.
Operators Autorecovery
Specifies whether to automate recovery. Recovery applies to operators that fail with a SYSTEM_ERROR and whose recoverable processes are in BLOCKED, RUNNING, or WAITING state when the recovery is triggered. When automatic recovery in configured and the previously inactive host group becomes active, recovery processing is done. Affected operators begin running on the specified remote host referenced by this host group and their processes continue execution.
Values:
Default: Inherit from Environment
Touchpoint Security
Specifies whether to inherit the value for Touchpoint Security configured in Environment properties, or set the value to true or false at the touchpoint level.
Values:
SSH Keys Path
(Optional) Indicates the location on the agent host where the private key file is stored. CA Process Automation accesses this location for the private key required when connecting to a remote host through SSH public key authentication. For example:
If the agent host has a Windows operating system, enter:
C:\PAM\SshKeys
If the agent host has a UNIX or Linux operating system, enter:
/home/PAM/Sshkeys
Important! Create the target path on the agent host.
Remote IP Address Patterns
Specifies any combination of the following, where IP addresses are static rather than dynamic. Click Add to create each row.
Remote Host Name Patterns
Specifies a group of remote hosts with a list of fully qualified domain names (FQDN) or regular expression patterns for a subdomain. Select Add to create a row for each pattern entry.
For example:
Remote User Name
Specifies the user name to assign to the user account on each remote host referenced by the host group. This name is used to connect to the SSH Daemon on the target remote host.
If you configure public key authentication, this value must be specified as the user-name in the command to generate key files.
Remote Password
The password associated with the Remote User Name. This same password must be defined in the user account defined on each host referenced by a given host group.
If using public key authentication with a passphrase, specify this value as the passphrase when creating the keys.
Maximum Number of Active SSH Connections
Specify the maximum number of concurrent connections that can be open simultaneously on any remote host.
Note: When that number is reached, further tasks wait for the next available connection.
Operating system
Indicate the operating systems of the remote hosts. Select from the following:
