Previous Topic: Properties: Host GroupNext Topic: Properties: Orchestrator Touchpoint
Properties: Orchestrator Host
The following fields appear on the Properties tab for the selected Orchestrator host. The following fields are read-only: Is Domain, Host Name, Orchestrator Name, and Status.
Note: For information about configuration, see the "Configure Orchestrator Host Properties" in the Content Administrator Guide.
Is Domain
Specifies whether the selected Orchestrator host is the Domain Orchestrator, where selected indicates True.
Host Name
Specifies the name of the host computer on which the selected Orchestrator is installed.
Orchestrator Name
Specifies the name of the physical Orchestrator host.
Status
Specifies the status of the selected Orchestrator host. Statuses include Active, Inactive, Active/Locked (and the name of the user who locked it), and Quarantine.
Operators Autorecovery
Specifies whether to automate recovery. Recovery applies to operators that fail with a SYSTEM_ERROR and whose recoverable processes are in BLOCKED, RUNNING, or WAITING state when the recovery is triggered. If recovery is set to automatic, when this Orchestrator becomes active again, each Orchestrator within the environment automatically initiates the recovery. Recovery starts running the affected processes and their operators begin running on this Orchestrator.
Values: This value can be one of the following:
Default: Inherit from Environment
Match target in Host Groups only?
Specifies the search scope for an operator target when the Target field entry is an IP address or a host name (FQDN). The operator execution on the target can proceed only when the target is known to CA Process Automation. Select Disabled to allow the broadest search. Select Enabled here and Disabled for the next field for the most restricted search.
Note: A DNS lookup of a specified hostname finds associated IP addresses; a DNS lookup of the IP address finds associated hostnames.
Values: The drop-down list has the following values:
Lookup DNS when matching target in Host Groups?
Note: This field is enabled when the "Match target in Host Groups only" is set to Enabled.
Specifies whether to limit the search through Host Group references to the entry type. For example: When the Target field entry type is an FQDN, search only host name patterns. When the Target field entry type is an IP address, search only subnets. When a DNS lookup is included, the search can also accept a host group reference to the other type, as resolved by a DNS lookup.
Values: This drop-down list has the following values:
Default: Inherit from Environment.
