Previous Topic: Touchpoint DataNext Topic: Catalyst Trigger
Triggers
One or more of the following fields appear on the Triggers tab for the selected node.
Note: For information about configuring triggers, see "How to Configure and Use Triggers" in the Content Administrator Guide.
Name
Lists the names of the four CA Process Automation triggers, with right-click options to Edit or View the selected trigger.
Description
Displays a short description of the corresponding trigger.
Enable/Disable
Specifies the status of each trigger at the selected node. This field is read-only for Orchestrator touchpoints.
Values: This value can be one of the following:
Default: Disabled
