General Properties displays an Add parameter icon, which opens the Catalyst Subscriptions dialog. A Catalyst trigger supports the specification of default values for properties that enable processes to be triggered upon the receipt of a Catalyst event. The following descriptions are for fields on each of the Catalyst Subscription tabs.
Each subscription references a Catalyst Connector with a filter.
Specifies the name of the subscription. This name appears in the Subscription List when you complete the configuration.
Specifies the Subscription ID associated with the named subscription.
Specifies the path to the process to execute when a matching event is received.
Specifies whether this subscription is enabled.
Values: One of the following:
Specifies settings for the connecting product.
Defines the UCF Broker URL.
Specifies a unique identifier of the connecting product. Valid entries appear in the drop-down list.
Specifies a unique identifier of the instance of the connecting product as registered in the UCF Broker. Valid entries appear in the drop-down list.
Specifies the events to process.
Specifies whether to process create events.
Values:
Specifies whether to process update events.
Values:
Specifies whether to process delete events.
Values:
Specifies the type of the entity.
Values:
Specifies the type of item. If not specified, then all types displayed in the drop-down list are included.
Specifies whether the connector recursively includes the item and its constituent children and relationships.
Values:
Specifies a specific object identifier (same as the MdrElementID).
Specifies the date and time after which to begin updating objects. Click the ellipses and select the date from the calendar application. Then, click OK.
Specifies authorization information.
Specifies the default user name.
Specifies the password associated with the default user name.
Specifies the username for UCF Subscription.
Specifies the password associated with the Username.
Copyright © 2014 CA.
