Previous Topic: Install Drivers for Database OperatorsNext Topic: Interact with the Desktop Configuration
Enable NTLM Pass-Through Authentication After Installation
NTLM pass-through authentication enables CA EEM to authenticate users using the NTLM protocol. This is an alternative to using credentials that users enter on the form-based login dialog. With the NTLM pass-through authentication, the login dialog is bypassed.
The following procedure does not apply if you already enabled NTLM pass-through authentication, for example:
You can enable NTLM pass-through authentication by manually adding ntlm.enabled=true to the OasisConfig.properties file. Use the following procedure only when you want to enable this feature but did not do it at installation.
  1. Log in as an administrator to the server where the Domain Orchestrator is installed.
  2. Navigate to the following folder, where install_dir refers to the path where the Domain Orchestrator is installed:
    install_dir/server/c2o/.config
  3. Open the OasisConfig.properties file with an editor.
  4. Use Find to locate the following property: ntlm.enabled=
  5. Change the value for the property to true, that is:
    ntlm.enabled=true
  6. Save the file and exit.
  7. Restart the Orchestrator service.
    1. Stop the Orchestrator.
    2. Start the Orchestrator.
  8. Repeat this process for each Orchestrator.
