Previous Topic: Start the OrchestratorNext Topic: Uninstall the Domain Orchestrator
Stop the Orchestrator
Only administrators with administrator credentials on the server where the Orchestrator is installed can stop the Orchestrator.
Important! If an Orchestrator is not shut down gracefully, the following temporary folder can build up several gigabytes of files. If this happens, you can safely delete the tmp folder:
install_dir/server/c2o/tmp
  1. Using Administrator credentials, log on to host where the target Orchestrator is installed.
  2. If you logged in to a Windows host, you can stop the Orchestrator service from the Start menu, the Services window, or the command line. Complete one of the following actions:
  3. If you logged in to a UNIX or Linux host, complete the following steps:
    1. Change directories to ${PAM_HOME}/server/c2o/. For example, change directories to:
      /usr/local/CA/PAM/server/c2o
    2. Run the c2osvrd.sh script with the stop option. For example:
      ./c2osvrd.sh stop
