Use this method to see the status of a start request.
<tns:checkStartRequestStatus xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <!--xsd:Choice Type--> <tns:interactionId>51</tns:interactionId> <tns:tagId>tagId__</tns:tagId> </tns:checkStartRequestStatus>
<?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <tns:checkStartRequestStatus xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <tns:interactionId>51</tns:interactionId> <tns:tagId>z34dsf5c7-xagb-4g5d-74g5-bd5c4we2378f</tns:tagId> </tns:checkStartRequestStatus> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
You can include one of the following:
<interactionId>: The user passes the ID of the start request form to view.
<tagId>: The user passes the tagId of the start request form to view.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <checkStartRequestStatusResponse xmlns="http://www.ca.com/itpam"> <startRequestStatus> <interactionId>51</interactionId> <state>Completed</state> <earliest-start-time>2012-03-01T12:51:25.690+05:30</earliest-start-time> <start-time>2012-03-01T12:51:25.893+05:30</start-time> <end-time>2012-03-01T12:51:38.033+05:30</end-time> <refProcess>/TENSU03/Process</refProcess> <processID>52</processID> </startRequestStatus> </checkStartRequestStatusResponse> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
The response contains tags under which the user can see the result.
<state> describes the state of the start request.
<earliest-start-time> states the time when the start request is queued.
<start-time> states the actual start time of the start request.
<end-time> states the end time of the start request.
<refProcess> shows the reference path of the process that is attached with the start request.
<processID> shows the Instance Id of the process (only returned if a process instance has been created).
Copyright © 2014 CA.
